Ir para o conteúdo principal
Replaced charging port and battery still won’t charge.
Before I started repairing the IPhone 6s it would not charged. When I examined the port you could see bent pins inside. Guessing that was the problem so I replaced the battery (just Incase) and the charging port. After I installed everything it still won’t charge. No it’s not the cable/usb port. I’ve read something about a chip on the motherboard that can go bad. Any thoughts?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I know the battery is working due to the fact the phone will turn since it has charge. Maybe a bad charging port. I’m going to uninstall it and reinstall then see if the situation changes.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Have you thought about trying the old battery with the new charging port?
Esta resposta foi útil?
Pontuação 1
Could be a bad charge port or battery too. I've had this happen in my repairs.
Pontuação 0
try ac power is that doesnt work try dc power is that doesnt work u can try and ask an employee for help
Pontuação -2
1 comentário:
You have no idea what you are talking about.
Please do not post bad information.
por
Adicionar a sua resposta
alex lee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 185
