Ir para o conteúdo principal
The HP Officejet 4630 is a wireless color inkjet all-in-one printer.
14 Perguntas Visualizar todos
Always shows error of paper jam
As soon as the device is powered on the printer shows error paper jam. Full disclosure this issue started to happen after a cat peed on it. It worked for a couple of days and now it is showing the same error again
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
cat pee is acidic. this must have caused some parts in the board to corrode and shorted out
Esta resposta foi útil?
Pontuação 1
2 comentários:
Firstly, why did the cat pee on it?
Secondly, since something is shorted you should check for anything that seems broken and replace it.
por
Was house sitting a friends cat. He must have been confused or something to something so random.
I suspect something similar too. Will have it checked.
I was hoping that I might discover a simple hack that can resolve the issue.
por
Adicionar a sua resposta
Nishit Rao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 756
