Ir para o conteúdo principal
The Alcatel OneTouch Pop Icon is a smartphone with an Android operating system. The release date for the Pop Icon was October 2014. Model number: A564C.
Rear camera replacement from different model
I am trying to swap my 5MP rear camera from Alcatel One touch pop icon (7040T) for upgraded MP camera from a different Alcatel model, leaving everything else the same. Will this be possible? Would I be able to take better, clearer pictures on the hardware side? Will the pins, ribbon cable length, angle be different and have connectivity issues?
Thinking about the donor camera from Alcatel One Touch Idol 3.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The answer is simple: no. It wouldn't be compatible on the hardware side or software.
You may be able to get better pictures if you use the HDR mode in your camera. I find this helps significantly even in low dynamic range images.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
rouf será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 110
