The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
Esta é uma boa pergunta?
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that. Most likely soldering a new connector to it should resolve the problem.
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Difícil
6 minutes
Esta resposta foi útil?
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 976
