Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Is my MacBook diying?
FIRST SORRY FOR MY ENGLISH
Since two days ago my macbook pro start to freeze with a white, pink, black screen.
I decided to dismount but after dismount three time the screen just dont swith on. I have experience dismount my macbook pro a lot of times.
Can somebody help me ??
Thanks you so much.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Your systems specs: MacBookPro7,1
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes your MacBook is dying. This is pretty common with a MCP89 issue.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I can use the compute for a long time if i dont move but how can i solve the problem with the sceen? anything to try?
por
Just to clarify this model has a NVIDIA GeForce 320M.
You do have a logic board issue with the GPU just the same! Someone with micro soldering skills might be able to repair the board.
por
Unfortunately, We cannot get good Nvidia or AMD chips. All that we can get are chips that will die very prematurely.
por
Adicionar a sua resposta
pillo pips será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 60
