Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
LCD display works, but brightness/backlight is dim
I just purchased a used MacBook Pro (13-inch, mid 2012). NON-retina display. Everything works fine, but the LCD screen seems a bit dimmer than it should. When I turn the screen up to full brightness, it doesn't seem very bright. When brightness settings are turned down low, the screen is nearly black. Everything seems to display okay, and the colors are fine. I calibrate the monitor with a Spyder 4 Elite, and the color rendering is acceptable.
Wondering if replacing the backlight would solve the problem? If so, is it possible to replace the backlight only, or would I replace the whole LCD? If it's the LCD, would I need to replace the entire LCD assembly or just the LCD panel. (I think these LCD panels have integrated backlights, but I'm wondering how to tell if the problem is in the backlight or somewhere else in the computer/display assembly.)
Other relevant tech specs:
Mac OS Sierra 10.12.6
Processor 2.5 GHz Intel Core i5
Memory 4GB
Graphics Intel HD Graphics 4000 1536 MB
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hey Charles,
To me the problem sounds more in the backlight circuit that drives your backlight screen and not the screen itself. (Most of the time this is because you spilled some liquid a while back or something). (most of the time the screen goes completely black).
Get it to a repairshop that does microsoldering on macbooks, it should be a problem they can fix.
if you have any questions, let me know
Kind regards,
Tom
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks. Would this fix require new parts? Any idea of how much something like this would cost?
por
Hey Charles,
Assuming this is the problem, the cost of the parts is minimal but the labour hours are extensive and needs to be performed by someone with some skills. Think around $200 for the repair.
Kind regards,
Tom
por
Adicionar a sua resposta
Charles Drexler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 850
