Ir para o conteúdo principal
No more rotation, compass, and health
Hello,
When I open the compass app nothing happens and just stays still
In the health app it doesn't detect my phone in devices
And my phone doesn’t rotate to landscape anymore
What could be the problem and how do I fix it please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Follow software suggestions made above.
But this sounds like the Gyro scope/ Pedometer is not working. It would require a board level repair.
Esta resposta foi útil?
Pontuação 1
There could be a few things that could be causing your issues
1) check for storage available on your phone? If your storage is full or over full it could cause all sorts of problems, its most common on the 8GB and 16GB units.
2) Check your iOS software version if it is out of date? If this is out of date then I suggest doing a Backup of the phone via iTunes ( make sure its up to date also) and then restore and update the phone. After done restore your iTunes backup to your phone.
(You can check both your iOS and storage by following : Settings > General > About. If you scroll down you will find all of the info for your phone.
Good luck
Pontuação 0
Adicionar a sua resposta
Muhammad Helmi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,182
