Ir para o conteúdo principal
Why is my Element tv showing only black and white?
I recently got my Element tv (model ELCFW328) back out of pawn and tried watching a movie. The menu is in color along with the tv being being blue before connecting the DVD player and putting it on component. When I do this the screen is black gray and white. Although the menu and the "channel" are still in color. I tried using different DVD players and even my Wii and everything turns up the same results. I tried placing the cords in all ways it could go and found that it only worked in the ones I had them in in the first place. I'm kind of frustrated and not sure what to do.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
I'm having a similar issue, except I just bought mine and unpackaged it from the box. I recently moved and needed a new tv...I haven't even set up my internet or cable yet. But, I tried hooking up my DVD player so I could at least watch movies for the time being. However, when I hook up the DVD player I get a black and white picture and it's fuzzy.
por
Chelsea: the problem is that you've selected "component" as a source. You need to select VIDEO.
por
I dont have video on the screen l did do av and got color but it keep blinking.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
do not click component. click AV
Esta resposta foi útil?
Pontuação 5
4 comentários:
You are a LIFE SAVER!!!!Thank you!!!
por
THANK YOU!! I've been trying to figure this out all day.
por
I've switched it to AV & it's still black & white?
por
Mines is still in black and white tho??
por
If the menu and other things are in color, than it's probably not a hardware problem. My guess is that whoever had the TV before you inadvertently switched it to black and white. Look in the settings of the TV, (especially under display) and try to find an option that says "Color" or something like that and make sure it's switched on.
Pontuação 1
I figured it out! Go to SOURCE. (button on controller) Do NOT select “component”. That’s your mistake. Select
“video”. I think that’s what it was. Audio video; something like that. But NOT component.
Pontuação 1
1 comentário:
Our Element only has TV--/Component,AV--/HDMI1--2--3,/VGA/ and USB setting when you try and watch a movie from DVD and put it on component or any other setting it goes back to TV without hesitation what's the problem
por
Adicionar a sua resposta
Monique Wilkins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 25
Duração total: 16,851
