Ir para o conteúdo principal
Informações de reparo e guias de desmontagem para laptops fabricados pela Haier.
Keys of keyboard are not working
Half of the keys of my haier 7G-5H are not working how to fix it?
how can i remove the keyboard?
thank you
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
I don't know about that specific model, but most keys are fairly simple to remove.
Before you remove them, just try to clean in and between the keys. This might help.
If this doesn't work, you can remove the keys. To do this:
1. Turn your computer off
2. Slide your finger or a flathead screwdriver under the keys you want to remove.
3. Lift GENTLY until the key comes off.
4. Rinse and repeat.
Now you can clean/ troubleshoot the troublesome keys. Keep in mind it may be a problem with your device and not the keyboard itself.
Esta resposta foi útil?
Pontuação 0
https://www.youtube.com/watch?v=24OkRfKy...
Pontuação 0
Adicionar a sua resposta
Yasir Farooq será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 2,859
