Ir para o conteúdo principal
A linha de fones de ouvido com cancelamento ativo de ruído da Bose chama-se “QuietComfort”.
Noise Cancelling Shorting Out
When I slide the control to Noise Cancelling, headphone keeps shorting out and goes in and out between total noise cancel and regular sound. Any suggestions?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
My power switch seems to not work. Van replacements be found?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
I found out that - as crazy as it may sound - in my case it had something to do with the battery brand I used.
I normally use Duracells, but always found them a bit hard to insert into the slot (it was really hard to close the lid with the battery inserted), but never had any issues until recently I bought a new pack.
Just for the sake of it I used a battery from a different brand - Varta in that case - and not only do these fit better: Noise cancellation works fine again! No more interruptions, problem solved!
Best regards, Ralph
Esta resposta foi útil?
Pontuação 2
Hi Erica, have you tried replacing the batteries and or connecting to another device?
Substituição da bateria do Bose QuietComfort 25
Pontuação 0
I have a similar problem, but for me the problem is actually the button itself, just touching it triggers static and it keeps dropping the right channel regularly.
Pontuação 0
2 comentários:
I have this problem too. I fixed it placing a small paper between the button (in "off position") and the headphone panel. It pushes the button a few mm inside the headphone and it appears to solve the problem. I think its a contact failure
por
what do you mean by between the button and the headphone panel?
A few close-up photos of this would really help!
por
Adicionar a sua resposta
Erica Rubenstein será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 39
Ao todo: 4,865
