Ir para o conteúdo principal
A Panasonic digital camera released in September 2013. The camera features 60x optical zoom and HD video and sound.
Msg "insert SD card again" or "try another card" msg when inserting m
Msg "insert SD card again" or "try another card" when inserting memory card; for all cards. ???
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Had that too. The SD slot got stretched a little when a card got stuck once and I pulled it out with a screwdriver. Solution was to add a little thickness to the SD card. Otherwise the metal contacts on the card don't touch the inside connectors ;-)
Esta resposta foi útil?
Pontuação 1
3 comentários:
What do you mean add thickness?
por
Add some layers of duct tape, for example, on the side w/o contacts.
por
It actually worked after multiple but then went back to the same situation, The reason is correct. its just frustrating, i really need my camera back. please help me out here.
por
If methods of @hellofellow won’t help, go to repair shop ans ask to diagnose SD Card slot, ribbon cable and MoBo. Changing slot might help.
Pontuação 0
Adicionar a sua resposta
dick giroux será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 31
Ao todo: 3,568
