Ir para o conteúdo principal
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
19 Perguntas Visualizar todos
large size pix. megabytes instead of kilobytes . too large to email.
pictures I download to pc now are like 2000 kbs instaed of 200 kbs. what setting did i change. too large to email.
Update (09/14/2017)
Hi, I could not find any compression/recording pixels or recording pixels setting. Canon SX120. Could it be called something else? Thanks John.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @trimmerbird, I think you had set to a higher resolution, etc
else, if the picture was taken, you can use online image resize to compress your pictures.
you can try this,
1. Turn on the Canon camera by pushing the toggle or turning the wheel at the top of the camera -- depending on your model -- to the "On" position.
2. Press the "Func/Set" or "Menu" button, depending on your PowerShot series.
3. Press the labeled buttons that serve as left and right arrows or press the "Omni Selector" wheel to scroll through the settings. Select "Compression/Recording Pixels" or "Recording Pixels."
4. Press the "Func/Set," "Func" or "OK" button to save your settings.
Tips
The recommended resolution for most digital photos is M2 or M3 at a resolution of 1,024-by-768 photos for some cameras as 1,600-by-1,200 for other Canon series. With this resolution, the Canon PowerShot produces clear photos small enough for emails but detailed enough for digital documents.
For high quality, space-saving photos at any resolution, set your compression setting to "Fine."
Credit:
http://smallbusiness.chron.com/change-re...
Esta resposta foi útil?
Pontuação 1
1 comentário:
It's the same problem when scanning docs on my Epson.
por
Adicionar a sua resposta
john trimmer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 74
