Ir para o conteúdo principal
O Asus Republic of Gamers G20 é um PC para jogos de formato pequeno com componentes de nível entusiasta e bom desempenho. Lançado em 2014.
Screen frozen on ASUS startup screen.
PC won't proberly boot, gives me an option to enter BIOS, if I leave it, it will just stay on the ASUS logo and a black screen. Previously I had a problem with the PC after a failed update. Any help?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Umm... Hi! I've been having the same issue and i'm wondering how you solved it. It would be great if you could get back to me, Thanks.
por
I have the same problem got it from my step brother and it worked fine, but then sat for about 4-5 months and now does this.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @robert1201,
what OS are you using ?
before any failed updates, do you encounter any issues, like bsod or poor performance of the pc?
I suspect either the operating system has crashed or hdd issues
If possible do a check on the HDD, hopefully inside bios has an option to test out.
check inside bios if your hdd is able to detect.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Robert Mullins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 3,223
