Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Can an SE be moved into a 5s housing?
I'm wondering if i can transfer all of my SE components into a custom 5s housing. I've looked around quite for other people that have asked the question, and it usually no since the iPhone SE logic board is supposedly slightly bigger.
However i've seen cases where people say theyve put an iPhone SE into a 5s housing shell anyway. Furthermore online there are 5s/SE custom housings, even though they aren't interchangeable?
I've looked at a lot of pictures online of the housings and i cant find any real differences. I might just dismantle my personal 5s and SE to see for myself.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
1 resposta
Pergunta mais útil
No, the internal size and screw holes are different.
Esta resposta foi útil?
Pontuação 4
8 comentários:
how do people supposedly do it anyway?
por
I've no idea. The camera and flash are different between the two models.
por
i just did it anyway. Flash wasnt really any different and camera fit anyway
por
Awesome! You should add a guide here on how to do it.
por
How do i do that? There wasn't really any difference except i kinda had to squash the nfc anetnna above the camera since there wasnt a slot for it. Other than that it was exactly like a 5s. The motherboard is technically slightly bigger, but the screw holes are the same.
por
Exibir mais 3 comentários
Adicionar a sua resposta
Bob Mcroy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 5,318
