Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1234 Perguntas Visualizar todos
Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
por
Adicionar um comentário
3 respostas
Solução escolhida
@refectio i just used the board as a donor, used almost all the parts.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Cool, at least you put it to good use.
por
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
Pontuação 0
3 comentários:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
por
This is unforunately the help you get in Apple forums.... a generic stupid easy answer that doesn't answer any of your questions.
por
Apple support is always giving basic unrealistic solutions to your problem, where in the world did you need latest software to have a well charging phone?
por
I Absolutely agree John
Pontuação 0
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 18
Duração total: 44,097
