How can I remove the jammed battery?
The battery is jammed in camera and is not holding a charge. I need to replace it but it is stuck in the camera. How do I go about removing the old battery and where can I get a new one?
Esta é uma boa pergunta?
2 comentários
I had this same problem. After reading the responses here, I used a thin spatula (used for frosting cakes), it is thin and not sharp. I was able to carefully wedge the spatula between the battery and the camera without puncturing the battery. After a few tries I got it out!
por Karen Olsen
Karen, I tried your trick with my LG G5 and it worked on the first try! Thank you!
por Reginald Whigham
