Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Screws stripped, trying to replace screen how can I get the screws out
Trying to replace my cracked screen but we can't get the screws out, they keep spinning so we are assuming they are stripped. What can I do to get them out? It is for the metal (?) piece that covers the screen part and it is the screws that are in the little tabs sticking up on the sides. Do I really need that panel to make the phone work? Help please!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
is the screen still on the phone?
Esta resposta foi útil?
Pontuação 0
I've seen people use rubber, like a rubber band, in between the screw driver and screw head to assist in removing stripped screws. If you could find a thin enough piece this may help in gripping the screw (with enough pressure).
If the screw is badly stripped I may even try and muscle a flat head in enough to remove the screw.
Pontuação 0
Adicionar a sua resposta
Bbob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 404
