Why does my engine die when the blade is engaged
my motor dies when I engage the blage
Update (09/01/2017)
Yeah, they spin.
I replaced the safety switch on blade engage assembly, and put a new blade drive belt on.
No change, I also checked the wires on seat switch, they were still connected. I had already ordered a replacement switch so, I decided to bypass the switch, same problem.
Esta é uma boa pergunta?
2 comentários
My Troy bilt had the same issue. Would die when engaging the blades. Turned out to be a spring type apparatus located near the shifter. You know when you put it in reverse the engine would stall out ? That's where the spring type thing is located. Once I pushed it around the blades would engage. Check this issue. It may be as simple as this.
por jdpc57
I have a 1 year old Craftsman DLT3000. The motor dies after a few minutes when the blades are engaged. Checked the fuel filter, took carb. bowl off and was no dirt in bowl. seat switch I disconnected and motor runs. the switch that engages after the blades are on seems to be working. Any ideas on what I can do?
por Ron
