Ir para o conteúdo principal
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 Perguntas Visualizar todos
How to repair outside crack glass of camera?
i recently bought oneplus 5 from amazon. it got a cracked on camera lens glass. the outside one.
please help me how to repair? does it comes in warranty?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
No clue if warrantee?
contact source ?
You're kidding _ Right.
One Plus 5
https://www.amazon.com/s/ref=nb_sb_noss/...
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi!
I think you should contact OnePlus support about that. If your phone is under warranty they will fix it for you.I haven't found a replacement glass online and even in our teardown there is no mention about the camera glass.
Esta resposta foi útil?
Pontuação 1
When some parts of your phone got cracked or deformed, you'll lose the warranty. You can go to OnePlus support center and you need to pay for it.
If you want to repair you OP 5 by yourself, you can watch video about this and see whether you can handle it. You need some tools to remove the battery cover and pop out the camera glass from the inside. And then replace for a new camera glass.
Pontuação 0
Adicionar a sua resposta
deep será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,790
