Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
The proximity sensor is not working after I replaced the screen.
My phone doesn't black out when i make a phone call like the exact same phone does. I replaced the proximity sensor and front camera cable and still nothing. What could it be?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@kennyck3
It could the following
Alignment the sensor has to be aligned correctly
The flex itself a lot of replacement flexes I've found are just rubbish they work for camera and speaker not the sensor
It could be the screen could be too dark could be too light
It could also be the connector the flex goes to, damaged from prying
Try a known good flex and align it like the original, try the original screen with the flex u think is good, always rule out bad parts first
por
Adicionar um comentário
1 resposta
You Change any others lcd? if not try any others lcd plz try.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
kenny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 163
