How do I access the letters instead of numbers on the dialup pad
can`t find anything on the dialup pad to change numbers to letters
Esta é uma boa pergunta?
That is what you dialer should look like. To use the letters under the numbers, enter the number to the count of the letter you want to use. For instance, if I wanted to enter the letter B, I press two twice. If I wanted to enter O, I press 6 three times. Understand?
Hope this helps!
Esta resposta foi útil?
thanks for your advice George. I pressed 2 twice, but all that came up was
2 twos. same with o, up came 3 sixes. What do you think?
Sounds like tom wants his password to be a word instead of a number. Like using the letters on a standard dial up phone to spell it out. For example WORD would be 9673
The answer given by George A. is totally wrong. The answer given by mayer is the correct answer.
Some carriers require a letter in the passcode to unlock the phone. I was FORCED to use a letter and now my phone is bricked because I can't type a letter after a system update.
Its not helping cause have tried so many times if l press 2 twice it gives me 22 while l need alphabet
Its doing my head in
How do I get the letters on my phone dial pad ?
So give me right way
Hi just discovered on my phone. Hold down the required key for a few moments and this works.
I went into my actual ‘pair a new device’ part of my phone and it came up with the complete keyboard!
You push the number associated with the letter I need
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 126,804
14 comentários
That's the way it will look. For instance, when someone's phone number is 1-800-CALL-NOW, their number is actually 1-800-222-2-555-555-66-666-9. That's how it looks. The letters are just so you can spell things in a phone number, but it's still just a number. To the dialer letters are just numbers.
por George A.
No answer …same question..how the !&&* do I access the letters and symbols on my Samsung Galaxy 7 phone key pad?
por danielpeggy59
I won't my old letter back I can read it
por Susan Held
How can I do this for a password with some numbers and some letters. It does not know what I am saying because it is not a word..
por janisjewelry
I have this problem, Human resources in my country lets me speak the first 2 passcodes they need to let me talk to someone then I'm asked to input a third which ends in a letter, (this is new) there is no way I have found to input anything but numerals, we are not talking about the corresponding letters assigned to each numeral on the keypad so we can work out what "1-800-CALL-NOW" is but to actually input a letter.
por isitcomputing
Exibir mais 9 comentários
