Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Black screen of death
So I got the "black screen of death" on my iPhone 7 128gb silver on iOS 10.3 while casually using my phone the other day. The screen faded to black slowly and wouldn't show again, I could feel the home button vibrate so I knew it was still on but the silent switch doesn't make the phone vibrate. so I tried soft reset- didn't work, tried letting it die then charging- didn't work, tried update- didn't work, finally tried restore in both Dfu and recovery mode didn't work, so after that I assumed maybe it was the LCD so I tried a new one that didn't work either.
Now I'm stuck with a paperweight iPhone 7 that is less than a month old, I would contact apple but I was told warranty won't cover it anymore since i opened it to try a new LCD. Is there anything you guys would recommend? Any and all help is appreciated, very little info about my problem online. Thank you for your time.
Esta é uma boa pergunta?
Pontuação 12
2 comentários
I though the article is useful. At least it helped me exit black screen......
How to Fix iPhone Black Screen of Death
por
can i buy it from you
por
Adicionar um comentário
10 respostas
Solução escolhida
Put the original LCD back on, and get the phone replaced under warranty. Do not tell them anything about opening the phone, just say one day it suddenly just died like that.
Esta resposta foi útil?
Pontuação 3
1 comentário:
You plug into your computer then on your phone you hold power button and volume up for 10 seconds then release volume up keeping your finger on the power button for 3 seconds. It will restart and nothing lost.
por
Hey , i have the exact same problem so I was wondering if you fixed yours at the end and how? What was the cause?
Pontuação 2
Just power it off by holding power button and volume down. If that doesn’t work try doing it while connected to iTunes. If iTunes logo pops up on phone, disconnect cable from iTunes and power off again. It worked for me. Good luck.
Pontuação 1
2 comentários:
Did this whilst connected to iTunes and nothing.
Disconnected and tried the 'power+Vol down' buttons which worked a treat!!
CEO's phone so saved having to send it off for repair!! Thanks a lot!
por
Power Button whilst holding volume down worked a charm!!!!!
por
hello
You Need Check Battery With Full charge..... and connect with iTune .. i hope your Phone connected.... if connected you have 2 Problem
1) Chargeing
2) Lcd Light
Thanks.....
I got Same Problem. And Solved..
Pontuação 0
This happened on a 7 that I fixed about two weeks ago, you need to order either this or something just like it.
https://www.amazon.com/Replacement-TranS...
Pontuação 0
1 comentário:
Dead link. Please explain what component you were referring to?
por
Just few hour ago,I still using my ip7 to watch FB live, after awhile I put it back into my pocket like usually did,when I come back home,I wondering why my phone is suddenly black off ,tried charge ,I can feel the electricity going through the phone , but it just black screen like that, vibrate no function, volume down+power doesn't work .... Just a sudden case , and that's the first time I experienced such weird thing,few thousand of photos haven't backup n some important data.... Frustration now.
Pontuação 0
IPhone 7 plus blacked out and keep going to other stuff without me clicking on it and seems like electricity going through it and it keeps blacking out and IDK why please help
Pontuação 0
My iPhone 7 plus wont turn on and I have a feeling that it just blacked out. Is there a way I can fix it?
Pontuação 0
My iPhone won't turn on
Pontuação 0
Here on 2025, my mom's iphone 7 plus just got the black screen of death ... We did all the things, with holding down button and power button at same time, - doing volume up, volume down and power button, nothing - tried draining the battery, this thing seems to have battery forever all of a sudden (when it would not hold too much battery usually 🫠) and now buying a new one! so sad there's no remedy!!
Pontuação 0
Adicionar a sua resposta
Poop mcgee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 90
Ao todo: 52,350
