Ir para o conteúdo principal
O Asus ZenFone 2 (ZE551ML) é um smartphone Android fabricado pela ASUS, lançado em março de 2015.
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
por
Different battery perhaps?
por
Do I have to try with a different battery? Can it be a motherboard's problem ?
por
Yeah, it could be either the mother board or the battery.
por
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Imagem de Asus ZenFone 2 Bateria
Guia
Substituição da bateria do Asus ZenFone 2
Nível de dificuldade:
Difícil
20 minutes
Imagem de Asus ZenFone 2 Placa-mãe
Guia
Substituição da placa-mãe do Asus ZenFone 2
Moderado
15 minutes
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
por
Adicionar a sua resposta
Vincenzo Liguori será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 680
