Ir para o conteúdo principal
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 Perguntas Visualizar todos
touch screen registering clicks in corner when not touched
Recently my touchscreen started having an issue where it though there was a touch/click in the bottom right corner. This stopped after I disabled the touch screen mechanic. I would like to know if there is any way to fix this so that I can use the touch screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I have seen a similar issue with other touchscreen devices. Most manufacturers offer a calibration program that is supposed to fix this issue (supposed to but doesn't always for me). Make sure the screen is cleaned properly since grime and dust can sometimes mess with the capacitive touch detection. Sometimes if you turn it off and clean it then use gloves or a thin cloth to configure the touch calibration it is less sensitive to atmospheric changes and statically charged dust. This can also be caused by a screen fault that necessitates the replacement of the screen (or you can just turn off the touch part of the display). I have sent so many devices back to the manufacture with this "Ghost" issue and it's never consistently clear what causes it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Graham Jordan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 17
Duração total: 1,292
