Ir para o conteúdo principal
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Perguntas Visualizar todos
VRAM Modules Pads or Paste
Going to upgrade the Kaby Lake CPU to a i7, upon reassemble should I use thermal pads or thermal paste on the VRAM Modules of the GPU, if pads what thickness should I use 0.5/1.0/1.5 or 2.0, like the ones used by EKWB on there GPU waterblocks, if paste should I go with K5-Pro, or the same thermal paste I use on the CPU Thermal Grizzly Kryonaut/Arctic Cooling MX-4.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Normal thermal paste will work just fine.
Esta resposta foi útil?
Pontuação 1
4 comentários:
If using thermal pads, what thickness should I use?
por
Has anyone measured, please? I have to order right thickness and delivery is like 10 days.
por
iMac 27” 2017 has a gap between VRAMs and cooler plate around 0.75mm.
por
Hi,
so a squeezed 1mm thermal pad should be fine, right? Do you think I need to use a little more thermal paste on the GPU die, in order to have the contact with the heatsink? Thanks.
por
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 919
