Ir para o conteúdo principal
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
door does not open
Drive side 2nd door does not open
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Can you clarify... Does it not open from inside or outside? If only fails to open from inside it could be that it is equipped with child proof lock switches and it has been activated somehow. If that is not the case and only fails to open from outside the lock to door handle pull rod has probably come loose some how. Failure of inside release handle could be a similar issue as well if it is only failing to open from inside release.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joe Shaw será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 102
