Ir para o conteúdo principal
Who know's what this cable is called and where to get one from?
Hi,
Whilst replacing the back housing of my iphone 5, I noticed that one of the contacts at the end of the cable was still attached to the main board, and had come away from the cable itself.
Does anyone know what this connection does (the square pad that the pry tool is next to)? I've tested the main bits of the phone and can't notice anything that isn't working even though the cable isn't connected to the connector any more.
https://d3nevzfk7ii3be.cloudfront.net/ig...
Also, do you know the name of the cable, as I want to buy a replacement one.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
This is an antenna flex cable.
iPhone 5 Interconnect Cable
Imagem de This pair of cables connects several components on the logic board.
Produto
$16.99
Esta resposta foi útil?
Pontuação 1
The straight cable is related to cell signal strength.
The angled cable is related to GPS signal strength.
^ Taken from the link @john provided
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 74
