Battery does not charging
When I replaced lcd screen digitiser after fixing everything . When I start charging with wall charger the flashing orange light on but battery not charging ?
Esta é uma boa pergunta?
I don't think the light is supposed to be flashing orange. It should be solid orange light indicating charging.
Are you able to get the battery charging screen displayed?
My guess is either damaged battery or charging port ribbon cable (or even the charging port ribbon cable connector on the logic board).
I've seen a few times where some people tried to fix the M8 themselves and end up damaging the zif connectors (The connectors you unclip then pull the ribbon cable out of) which is a PITA to fix.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 408
1 comentário
Thanks I managed to fix it
por Abid b Hussain
