How do you replace the fuel filter?
How, and after how many miles do you change the fuel filter on a 2015 Toyota Corolla?
Esta é uma boa pergunta?
See if this video is what you are looking for.
Esta resposta foi útil?
You should just be able to pull up the back seat and there will be a hatch under there.
'**Disconnect the battery before you do anything!!!**'
Pry off the hatch and you will see a white assembly with a black collar.
Unplug the electrical connector, and move the lid out of the way.
There will be a black fuel line that you have to disconnect. IT WILL LEAK FUEL so have some rags ready.
(there are other methods like trying to start the car with something disconnected to empty the fuel line but I cant recall that exact procedure.)
Once thats done with you can just unscrew the collar and swap the assembly or replace the filter.
Personally I would do it every 100k miles or thereabouts.
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 46
Ao todo: 13,661
