Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930.
425 Perguntas Visualizar todos
Should I replace motherboard or LCD?
Hello, my phone has recently taken a trip to the washing machine and when i took my phone out the screen was green but the samsung logo was visable. After drying my phone, I switched it back on and the screen wouldn't come on but the device worked fine, i rang it, it came through and i could hear notifications. After inspecting the connection for the LCD, i noticed that there was a gap on the pin and the ribbon connector had something on it.
Here are some photos:
MotherBoard connector:
http://imgur.com/a/Cmjjp
LCD ribbon:
http://imgur.com/a/NgHhl
Esta é uma boa pergunta?
Pontuação 0
3 comentários
is there another way to view the photos i can't view them
por
I'm having no problem seeing the images, using Safari.
por
Adicionar um comentário
1 resposta
Solução escolhida
The connector doesn´t look well. I think one pin is broken. It is possible to replace only the connector instead of the whole motherboard. But it is very hard to say if there aren´t other broken components on the logic board caused by the water. I think you better bring this phone to an expert he will tell you if it´s worth to repair the phone or better to buy a new one.
Esta resposta foi útil?
Pontuação 1
2 comentários:
How is it possible to fix that one broken pin?
por
i feel bad 4 u :(
por
Adicionar a sua resposta
Daniel M Musson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 715
