Ir para o conteúdo principal
Released March 2016, 7.0" Galaxy Tablet by Samsung.
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Solução escolhida
If you are charging it via your computer, switch to a charger.
Esta resposta foi útil?
Pontuação 3
1 comentário:
No, im charging it with its charger. But there still an X mark
por
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
Pontuação 0
1 comentário:
I’ve got a 51 located on the battery icon. What does that mean
por
Mine does the same thing but I just got a new battery so I know it’s not a battery problem.
Pontuação 0
Adicionar a sua resposta
aju shee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 13,767
