Ir para o conteúdo principal
Announced on September 9, 2015, the iPad Mini 4 maintains the power of an iPad Air 2 in a smaller form factor.
Weird issue with lock button after screen replacement
the digitizer and lcd work just fine and light up when i press the home button, however the screen dosent respond when i press the power button it just stays dark. if i hold the power button "slide to power off" shows up and when i hold the power and home button the ipad restarts....so i know the power button is working. ..has anyone seen this before? or know whats causing it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
i found the problem, it was a small cable by the fpc connector that had to be desoldered from the old screen and soldered into the new one.
seems like everytime i post a question on here i just end up answering it myself...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
lukerockhill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 101
