Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2265 Perguntas Visualizar todos
iPhone freezes after a while
Hello,
Recently I replaced the lcd + digitizer on an iPhone 7. After a test everything works, but after a while the iPhone locks up while using: the screen freezes (still showing everything) but the digitizer doesn't seem to be reacting.
The only thing that works is a soft reset ( power down + wake). After reboot the iPhone works again.
But the problem returns so a soft reset is needed again.
First time I'm having this issue. Is this just a faulty screen?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
it does this with the original screen also? if not then you have a replacement screen issue
por
Adicionar um comentário
2 respostas
Hello! Does the device seem hot?
Esta resposta foi útil?
Pontuação 0
Classic symptom of a faulty screen, try another one!
Best of luck with the repair :)
Pontuação 0
1 comentário:
Thanks for your reply. The soft reset was needed 3 times day after repair. But now we're 1 day further and it only happened once. Could it be related to some static electricity or something? If it keeps happening I will replace the screen of course, but we're waiting an extra day to see if it resolves by itself or not.
por
Adicionar a sua resposta
FD Tech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 125
