Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Image layering after fix
After fixing an ipad mini 2, the screen is layering images with mild transparency. Anything the screen has shown since turning on will remain partially in the foreground of the screen and small patches of horizontal lines have appeared along the screen. I have checked the cable and the connection to the logic board and both are sound. My suspicion is that I need to replace the LCD, but I'm hoping otherwise.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
My first guess would be to check the connections but since you've done that you should definitely try a new LCD.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Snap White será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 87
