Ir para o conteúdo principal
Fifth generation of iPad, released in March 2017. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A9 processor.
What model exactly is the "Latest Model" 2017 MP2G2LL/A iPad?
The "Latest Model" for example MP2G2LL/A, MP2H2LL/A etc,, is this an iPad Air 2 or? Mainly trying to determine the replacement digitizer (or screen) for it. Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The MP2G2LL/A is:
Apple iPad 9.7-Inch 5th Gen (Wi-Fi Only) 32, 128 GB Specs
Identifers: iPad 5th Gen (Wi-Fi) - MP2G2LL/A* - A1822 - 3017* - iPad6,11
http://www.everymac.com/systems/apple/ip...
Parts are here:
iPad 5 Wi-Fi
iPad 5 Wi-Fi Front Panel Assembly Replacement
iPad 5 Screen Digitizer
iPad Air, iPad 5, iPad 6 Adhesive Strips
Imagem de Replace a screen compatible with iPad 5 A1822 A1823 and iPad Air (1st Gen) A1474 and A1475. Includes all of the small parts preinstalled in the assembly. Part #821-4894-A.
Produto
$49.99
Imagem de Replace the custom cut adhesive strips that secure the front panel to the case compatible with the first generation iPad Air, iPad 5, iPad 6 model A1474, A1475, A1822, A1823, A1893, A1954 tablet.
Produto
$6.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you your help & reply. So this is actually the (1st Gen) Air digitizer? Oooook, just looked through the repair link above, yes the touch ID sensor. Bit different from the Air 2 on that sensor. Thank you so much, very helpful!
por
Are batteries available for 2017 IPad 5 model
MP2G2LL/A.
Pontuação 0
Adicionar a sua resposta
Don será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 11,518
