Ir para o conteúdo principal
First flckering,now not turning on.
I have an iPhone 6s that someone wanted me to fix. Said that lcd was not working. Swapped an new lcd and got flickering and stripes. Charged it for an hour and got 40% battery. Worked for a while. Friend took it home and said it flipped when charged,flickering screen and shutting down. He said there was a bad battery before. I took it back,swapped a new battery,nothing. Not turning on. Tried the old battery and lcd,nothing. Then changed the charging port,still nothing. I've tried everything,what is wrong with this phone? Soft reset not helping,tried for 5 minutes and still nothing. :(
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like the issue may be a little deeper then a component replacement. You have done all the things I would have so I would imagine there is an issue with the logic board itself. It may well have fried itself now though
Esta resposta foi útil?
Pontuação 0
2 comentários:
It seems to go to DFU mode though. So there is something still alive inside.
por
Left it on charger for an hour and it turned on but apple logo was there only few seconds and then flickering again.
por
Adicionar a sua resposta
Milla Hurme será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 38
