Ir para o conteúdo principal
Released in 2006, identified by model number PP20L for e1505
17 Perguntas Visualizar todos
Good source for a Express card 16GB SSD under $30
My laptop has bad overheating issues at the HDD because it's constantly running at Max load. I need a 16 GB expresscard SSD which would be just enough for Ubuntu. Does anyone know of a good source for a SSD under $30? I'll never use my expresscard slot anyway, so this may put it to use. It's a 54/34mm slot. Or an adapter solution. Thank you.
@danj @mayer Anyone?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Anyone? Anyone?
por
Adicionar um comentário
2 respostas
Solução escolhida
@pccheese - George, I doubt you'll find one for so little. How about a micro-drive like this: IBM 1GB Micro-drive
Esta resposta foi útil?
Pontuação 2
2 comentários:
Alright, thanks. Do you know if I can use my wireless card slot for an SSD?
por
I doubt it as the needed driver may not load
por
I found the reason my HDD was overheating. In the BIOS, there is an HDD option for quiet, performance, and bypass. I suspect the performance mode forces more voltage that this cheaper HDD can't handle, and overheats. I put this settings on bypass and now the HDD stays much cooler.
Pontuação 1
Adicionar a sua resposta
George A. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 350
