Ir para o conteúdo principal
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Perguntas Visualizar todos
Can I upgrade the 2TB fusion drive on mid 2017 27 inch iMac
What kind of SSD does apple uses for its 2TB fusion drive? I read on your website that the 2TB is composed of 128 SSD and 2TB 7200 rpm drive. Can I upgrade the 128 SSD with a 3rd party nmve m.2 ? Is there an adpater for it?
Esta é uma boa pergunta?
Pontuação 8
1 comentário
Remember: You can only put ONE partition on an Apple Fusion drive.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Do not use the M2 blades in a Mac, They are not reliable. Either go with an Apple original or an OWC. Basically in a fusion drive set up the SSD acts as a cache. Why do you feel you need a larger one? You may be trying to upgrade the wrong drive. What are you trying to accomplish?
Esta resposta foi útil?
Pontuação 4
The fusion drive is in the pc world a hybrid drive.
Conventional hard drive platters with a ssd portion of memory on the controller board. You can't simply swap out the Chip and attach a nmve m2...
Your only option is to purchase a bigger hybrid hard drive..
Pontuação -1
1 comentário:
While it does have similarities to a Seagate FireCuda hybrid SSHD, which has a SSD setup as a read/write cache. A Apple Fusion drive is physically two drives! a SATA HDD and a PCIe blade SSD. So both drive bays are used. In addition, the OS controls the cache not the hardware as in a SSHD.
BTW - I often put in FireCude drives into Mac's as they have an advantage over a standard HD and only require one port. If someone needs performance then I try to get them to go with the blade SSD over the SATA drive, as a dual drive setup is superior! Than a Fusion Drive setup.
por
Adicionar a sua resposta
Ria será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 17
Últimos 30 dias: 25
Duração total: 9,817
