Ir para o conteúdo principal
O Samsung Galaxy S6 Edge+ é a variante maior do smartphone Galaxy S6 Edge. Problema de carregamento
S6 Edge+ totally dead solution.
Hello! I have an Galaxy S6 Edge+ that it is totally dead, not responsive on charge, not power on, nothing... just black screen. Can i know which part of my phone is responsabile for this problem? Please i need this.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Have you tried connecting your S6 Edge+ to a laptop or PC? If the computer reads it then it could very well be on and just the display is out.
Otherwise, if it is truly dead then your battery may have lost charge - they sometimes can drain so low that the USB charger will not be able to charge it. Maybe try a wireless charger or have the battery replaced. Unfortunately you can't easily externally charge the internal batteries of the S6 Edge+
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lind cerri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 5,171
