Ir para o conteúdo principal
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
35 Perguntas Visualizar todos
Pergunta encerrada
Please help me bypass this Reactivation Lock
Purchased a Gear Fit 2 and the person didn't unlock it from its original account. Now I can't use the device. Is there a way to bypass the reactivation lock or reflash the watch to go back to the factory default so I can use it?
Esta é uma boa pergunta?
Pontuação 6
4 comentários:
I need help to take off the account that had it went to restset it an it's telling me I need his acc or sum like that an I can't use my s2 watch
por
Why would you not wanna go back to factory default?
You should always wipe things when you get them as you dont know what could be on them and that could get you in alot of trouble.
So just wipe it. There is nothing that concerns you. Or you could ask the person you bought it from for the code.
por
I have attempted to use the factory reset but that doesn't erase the reactivation lock. I appreciate your assistance however that doesn't work. I contacted the person that sold it to me and they gave me a run around and then stopped communicating with me. I contacted Samsung and they too said that the account that locked it should unlock it. That is why i am reaching out here to see if anyone could help me.
por
Did you ever bypass the reactivation lock?
por
Adicionar um comentário
5 respostas
This function is used to lock factory reset and wipe device! Join in contact to your sale and request to unlock on his samsung account! If the device was not stoled, he will do it easily! However! If the device was stoled you will be finded easily.
The sale must to join on samsung account at "Find My Mobile" (https://findmymobile.samsung.com/) then unlock at the padlock icon.
Best Regards.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No not necessarily. My watch was not stolen and it won't unlock and keeps resetting itself
por
Hi
you can go to this video and use this method.
Shows your how to remove the FRP lock.
https://youtu.be/YZ_AxFpiktg
Pontuação 0
Check this out: https://knockinheavensdoor.blogspot.com/... - this is for gear sport but you will get supporting info and files from: https://forum.xda-developers.com/t/react... (be patient and read the entire thing. It'll work).
Pontuação 0
Hi, I fixed a Galaxy S4 with the reactivation lock. I wrote a bypass on my site. You (probably) do not need a PC. https://www.thetechboy.org/2021/12/samsu...
I hope this works well for you.
God Bless,
TheTechBoy
Pontuação 0
I have solution 4 this problem...plz see this video tutorial.... and link the all combination files... plz pray 4 me thanks regards
https://youtu.be/rCDouih8QtQ
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 34,635
