Ir para o conteúdo principal
Pergunta encerrada
iPhone 6 No Wi-Fi Signal? -- Nothing seems to work
Sometimes it can detect networks if you are extremely close to the router. This issue definitely isn't software because I have reset all network settings and restored via iTunes.
I replaced both the antenna AND the flex cable, and it seemed to work fine afterward, so I put it back into my case and the problem instantly comes back. Since the case requires a lot of force taking it in & out, my theory is that when this happens it puts strain on the rear housing and damages signal.
So I decided to buy another flex cable and replaced that, but to no avail.
Is there anything I can do besides buying a new housing and crossing my fingers that it'll work?
(BTW: the phone is past its warranty & can only reliably detect 5Ghz networks, though not very good)
Thanks for your help/guidance, it's much appreciated
- John Baker
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you replace the L shaped antenna?
Esta resposta foi útil?
Pontuação 2
1 comentário:
Yes, the L-shape and the actual antenna
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 98
