Ir para o conteúdo principal
A powerful, bagless, upright vacuum cleaner part of the DC-series released in 2009. Its model number is 15804-01.
11 Perguntas Visualizar todos
no rotation on brush area at head
when I turn the unit on, it does the vacuum , as I can hear the units sounding, but when you put the floor portion to use, the brushes do not turn at all like they once did. is this a repairable item? I know there is no belt connected, so something else is wrong.
Esta é uma boa pergunta?
Pontuação 3
3 comentários:
@deewhy are you referring to the brush roll which is part of the cleaner head assembly? what have you checked?
por
yes that is the area, and we pulled the cover off the bottom only to see no belt there.
por
there is still good belt . At first I thought it was belt torn. So I did order belt , and not needed but somethings else ?
por
Adicionar um comentário
1 resposta
MY serial # is 175-US-A51394 I did not find it. My brush roll does not turn. I cleaned all thread and hair etc, from rollers and it still does not turn. What do I do. Thank you.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dennis Young será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,469
