Ir para o conteúdo principal
O smartphone Android Xperia Z5 Compact da Sony possui um display eletrônico LCD IPS de 4,6" com resolução de 720 x 1280, processador quad-core Qualcomm Snapdragon 810 e 2 GB de RAM. Lançado em outubro de 2015.
Notification led blinks 4 (four) times?
I was have problem with my lcd: there was picture but no backlight.
Then;
1-Pulled off battery
2 -Cleaned flex cables with alcohol.
3-Putted everyhing back.
4-Putted battery back.
5-Tryed to power on.
Now:
When i try to power on vibrates 1 time as normal and 5-6 seconds later red led blinks 4 (not three) times. No thing happens. If i try to shut down by sim slot button its acts normaly and vibrates 3 time.
Anyone knows what is the meaning of 4 time led blink.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Sony Online Support emloyees made me crazy. I find my own answer. When lcd or backlight is broken or cant work properly device prevents boot up. 4 time blinks wants to say that! Thanks for Sony's ignorant employees.
Esta resposta foi útil?
Pontuação 0
3 comentários:
i disassbemled my lcd's flex cable and phone booted up normaly (without picture of course.). I will buy new lcd.
por Compartilhar
Did new screen solved the problem ?
por Compartilhar
What is an icd?
por Compartilhar
I replaced the LCD screen and back camera. Now it won't boot up. There is no response at all from any of the reset option. The 120 second reset. The power+volume up, power+volume down. Nothing. When I connect to charger and hold down the power button, the red LED comes on for a second, then turns off, the phone vibrates 3 times followed by the red LED turning on again for a second and then turning off. Then the process repeats. Holding down the power or the 120 second restart button while plugged in yields the same results. I tried repair using pc companion, doesn't work.
Pontuação 0
Adicionar a sua resposta
mehmed akif ay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 5,125
