My charger will not fit into the port. How can I fix the charging port
The chargers will not go in. I think the charging port needs repair. How can this be done on LG Optimus L90
Esta é uma boa pergunta?
Is the port bent? Are one of the prongs inside the port popped up? If either one of those is a yes. then you need to replace the port on the actual phone. If none of those is thne problem. Try getting a new charger and see if that works. Or try putting it in on an angle.
Goodluck!
-JR
Esta resposta foi útil?
Yes the problem is the prongs are messed up. I tried with different chargers but nothing seems to work. Can you show me how to replace the charging port?
Thanks
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 70
Thanks
por Abhi Shah
