batt ery keeps draining
I have a 2003 ford ranger a day a go the battery started draining when truck is shut off ware do I start to problem shoot ? any help would be nice thanks John.
Esta é uma boa pergunta?
What's the batteries voltage? Are the POS NEG cable conn tight? When you turn the key where is the battery gage needle pointing? While driving, where is the gauge. While driving, your battery should be charging. If not, the problem could be the alternator. Most auto parts stores will test the battery and alternator for free.
Esta resposta foi útil?
thank you sweetie for the input but both the battery is good an the alt is working grate :)
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 326
