Ir para o conteúdo principal
Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
HDD Not getting detected?
Hello!
I was cleaning my Mac Mini and i removed temporarly the HDD of it. After i placed it back in i always booted into the recovery system.
When i plug the HDD into my Windows PC and open a recovery tool all the Files are still there, but my Mac dosent accept the drive, why?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Opps! You may have altered the boot blocks when you connected the drive to your Windows system.
Do you have access to another Mac? If you do you might find using it to either connect your Mac mini to using Target Disk Mode or use it to create a bootable drive so you can run Disk Utility to repair your drive. In this case you don't want to use the recovery partition's Disk Utility.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks!, got all my data saved.
por
Adicionar a sua resposta
Karrigallu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 93
