Ir para o conteúdo principal
O C720 é um Chromebook de baixo custo da Acer baseado no ChromeOS. Lançado em 2014, é o sucessor do C710.
Why does my chromebook keeps crashing?
i recently bought it and i noticed that it oftem randomly shuts down. though i can turn it back on, i find this occurance to be happening a lot that i find it annoying... around how much would it cost me to have it fixed?
thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
It depends on what is crashing your computer. Do you get any error messages or the Blue Screen of Death showing briefly? Does the computer slow down and finally shuts down? These kind of errors are generally indicate a problem with the operating system. If the computer shuts down very quickly, this may be a heat problem with your computer. Most hardware problems are consistent and shut down or not start up at all.
The cost to reinstall the operating system should not be too much and you can probably do it your self. Repairing hardware depends on the part that failed, the system board is a higher cost to repair than memory. A good tech should be able to sort out if the problem is hardware or software and give an estimate of repair cost.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Christine Aquino será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 2,220
