Ir para o conteúdo principal
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Memory module could be fried?
I took my tablet in to be fixed. It will show the Samsung logo, and the batery icon but that is it. They said it was the menory module was fried... what does this mean and how do I fix it? I can get it into Odin mode, but when I try to connect it to the computer, it is not recognized. Any help would be appreciated. Thank you for your time.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Who told you that the memory IC is fried?
por
Please see my recently asked question as it may be the solution for you.
por
Adicionar um comentário
1 resposta
ODin Mode requires Samsung USB Drivers for the PC.
You can download them here:
http://developer.samsung.com/galaxy/othe...
If it then recognizes the phone on the PC, then download the appropriate Samsung firwmare and ODIN from https://www.sammobile.com/firmwares/
You can follow these instructions to reflash, but use the sammobile firmware.
https://androidmtk.com/flash-samsung-sto...
Try each available version of firmware if the first one you download isn't successful.
If none of them work, your tablet may have other issues on the motherboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kamari foxx será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 156
