Ir para o conteúdo principal
No display after battery replacement
A customer brought the device to me saying it needed a battery. Device showed no signs of life.
I replaced the battery. The logic board heated up but no picture. Also, i did this repair without removing the front panel assembly.
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Try another screen, known working charger battery?
Also does it detect via computer in iTunes in case of a no backlight issue?
por
I tried an authorized charging and nothing. I thought about trying another screen. I'll give them the option because they bought it from someone else so there's no telling what prior issues that it had.
por
But still no picture
por
Adicionar um comentário
4 respostas
I would suggest disconnecting the front panel assembly while replacing the battery. Then try booting your device up with the new battery. If it does not turn on or show signs of functionality, I would look into replacing the logic board.
Esta resposta foi útil?
Pontuação 0
Maybe it gone in DRY mode try to connect with itunes... then unique option is restore
Pontuação 0
Do you notice this:"The logic board heated up ", what happened to it?
Pontuação 0
Yes the logic board did heat up quite a bit
Pontuação 0
Adicionar a sua resposta
The Wizard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 98
