speakers won't put out any sound
Why does it display Headphones on screen when I try to adjust volume and no sound comes from speaker?
Esta é uma boa pergunta?
Get a pin or something like that and give the headphone jack a good clean out.
They gather fluff up there and it could be causing the problem.
If that doesn't work then it would need replacing.
Not a massive job so it should be a cheap repair at a local shop if you aren't confident enough to do it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 56
Are you referring to the built in speaker or did you connect an external speaker to the iphone? Then headphone icon would indicate your have a plug in the headphone connector - but what is connected? Is it a powered speaker, does it have a volume control? Does the phone normally work as a phone?
por Spikey2
